Enable the RADIUS accounting interim request feature to create a log whenever more than the specified number of CLI commands are executed.
- Select RADIUS.
- Select the RADIUS Global tab.
- Type the number of CLI commands in CliCmdCount.
- Select Apply.
RADIUS Global Field Descriptions
Use the data in the following table to use the RADIUS Global tab.
Name |
Description |
Enable |
Enables the RADIUS authentication feature globally. |
MaxNumberServer |
Specifies the maximum number of servers to be used inclusive. |
AccessPriorityAttrValue |
Specific to RADIUS authentication. Specifies the vendor-specific attribute value of the access-priority attribute to match the type value set in the dictionary file on the RADIUS server. The default is 192. |
AcctEnable |
Enables RADIUS accounting. |
AcctAttriValue |
Specific to RADIUS accounting. Specifies the vendor-specific attribute value of the CLI-command attribute to match the type value set in the dictionary file on the RADIUS server. This value must be different from the access-priority attribute value configured for authentication. The default value is 193. |
AcctIncludeCli |
Specifies whether you want CLI commands included in RADIUS accounting requests. |
ClearStat |
Clears RADIUS statistics from the device. |
McastAttributeValue |
Specifies the value of the Mcast attribute. The default value is 90. |
AuthInfoAttrValue |
Specifies the value of the authentication information attribute. The default value is 91. |
CommandAccessAttrValue |
Specifies the value of the command access attribute. The default value is 194. |
CliCommandAttrValue |
Specifies the value of the CLI command attribute. The default value is 195. |
AuthInvalidServerAddress |
Displays the number of access responses from unknown or invalid RADIUS servers. |
CliCmdCount |
Gives the value for the CLI command count. The default is 40. |
CliProfEnable |
Enables RADIUS CLI profiling. |
SupportedVendorIds |
Shows the vendor IDs that the software supports for RADIUS. |
RadiusReachability |
Specifies the mode for RADIUS reachability. Status-server mode provides a standard-compliant method for RADIUS reachability. Use-radius mode requires the configuration of dummy packets that are sent to RADIUS servers. The default is use-radius mode. |
SecureEnable |
Enable RADIUS Security (RADSec). |
UserName |
Specifies the user name for RADIUS server reachability. The default is extremenetworks. |
Password |
Specifies the password for RADIUS server reachability. The default is extremenetworks. |
Confirm Password |
Confirms the password for RADIUS server reachability. |
Unreachable Timer |
Specifies, in seconds, the interval between checks when radius server is unreachable. The default is 60 seconds. |
Keep Alive Timer |
Specifies, in seconds, the interval between checks when radius server is reachable. The default is 180 seconds. |
